Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Which Mesh system?
Pauldennis
Which Mesh system?
I have a house which front to back is 12m and a garden which is 10m. My modem / router, located at the front of the house, is one box, and I want to cover both house and garden. I was thinking either the AX 1800 or the Orbi RBK20. Ideally WiFi 6 would be good for the future but range is more important. I need the furthest extender to be able to cover the 10m garden and hence the router to cover 12m if possible.
I have 25 connected devices but 5 are Alex's.
Current broadband speed is 60meg but will upgrade to 100meg when that comes available in 6 months.
Thx
Message 1 of 4
Accepted Solutions
Guru
Re: Which Mesh system?
the rbk20 would handle 150mbps setups fine.
I'm a fan of the triband mesh systems compared to the dual bands. But i haven't used the AX1800 yet so I have nothing to compare to it.
Message 4 of 4
All Replies
Guru
The RBK20 is a solid system. And the benefit is you can add satellites if you desire additional coverage. Versus I don't usually recommend people add more than 1 wireless extender.
Message 2 of 4
Pauldennis
My ISP is soon to provide 150meg download, so would the RBK20 still be ok? Our since the end to end length to be covered is 40 meters would the RBK23 be better since you get 3 units?
Or the AX1800 would 3 units. This doesn't have the dedicated backhaul so not sure?
Message 3 of 4
Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3094 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
