- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wifi Mesh 6 connects to internet but will not broadcast to connected devices.
- Mark as New
- Bookmark
- Subscribe
- Permalink
We recently had a power outage and upon performing a factory reset and implementing the previous settings I had prior to power outage, I can not longer connect to internet via WiFi connection. I have verified that the modem is still pushing internet with a direct connection, however when I plug into the base station of my Nighthawk Mesh and attempt to connect to the internet, it connects but without internet. I have also attempted to change my WiFi broadcast settings to something different than what I had before and I get the same results. Could the power outage corrupt my mesh system?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wifi Mesh 6 connects to internet but will not broadcast to connected devices.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-rout...
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
