StanH's avatar
StanH
Tutor
May 12, 2021
Can I remove NETGEAR USB Control Center?
Should I remove "NETGEAR USB Control Center" 11/21/17? The three buttons on its screen are grayed out. Only [About] works. I think it might be replaced by Netgear Genie 8/19/2020 or otherwise not being used. I have a USB printer connected to a R7000 and that works. There are no problems with the way my network runs right now. It just seems like that component is not doing anything.
  • Update -- more information:
    I suspect this is left from a previous router, not the current R7000. Date on exe: 7-29-2013, software v1.36, driver v1.83.35.
  • michaelkenward's avatar
    michaelkenward
    That is to control printers.
    The USB control centre is not the Netgear Genie?
    • StanH's avatar
      StanH
      Tutor
      More Information:
      Windows Defender Firewall has blocked some features of control center.exe. The message is "This app has already been blocked or unblocked for a different network type" I don't understand the message. Is control center.exe needed for my R7000 network? I do have a printer on the R7000 USB port.
      Kile Location:
      C:\program files (x86)\netgear\usb control center\control center.exe
      Date:
      7/29/2013 11:28 AM
      Size:
      4,019 KB
        michaelkenward
        You can get some insights into the message, and what is going on, by visiting this bit of Windows:
        >> Control Panel >> System and Security >> Windows Defender Firewall >> Allowed applications
        In my case there is a whole raft of things. I usually allow them through:
        Firewall Allowed applications
        As you can see, there are several Netgear things in there.
