Leodee's avatar
Leodee
Can not connect to MyQ
Background: I moved in a new house with a brand new MyQ garage door opener. I set up my  internet with SuddenLink and connected MyQ to the Suddenlink wi/fi router. Everything worked perfectly.
I thought I could improve my wi/fi by replacing the SuddenLink wi/fi router with the Nighthawk AC1900. I easily transferred my two phones, two TVs and two laptops to the AC1900.
The problem is I can no  longer connect the MyQ to the AC1900. At first the MyQ would discover the AC1900 but failed when I entered the password. (Same password us on my other devices and what is shown on the AC1900).
I subsequently reset both the MyQ and the AC1900 and now I can not discover the AC1900 at all.
On the AC1900 it states "This product does not support Home Phone Services....." Would this be a contributing factor for not working?
Can you recommend another wi/fi router that will connect to MyQ in case the one I have now is incompatible?
  • FURRYe38's avatar
    What is the product and model# of your NG router? AC1900 isn't a model#.
    Did you set up the same SSID name and PW on the NG product as used on the other router?
    • Leodee's avatar
      Leodee
      Sorry, the model is C7000-1AZNAS|Nighthawk AC 1900 WiFi Cable Modem Router. On the box it says C7000-100NAS.
      No I did not change anything and at this point do not know what the SSID I was using. I set up all my other devices using the Netgear info.
  • plemans's avatar
    When your setting it up, is your phone connected to the 2.4ghz or the 5ghz?
    Make sure your phone is on the 2.4ghz as MyQ is a 2.4ghz devices.
    • Leodee's avatar
      Leodee
      Yes, all are connected to 2.4. The 5g does not appear as an option. I guess I will have to talk to the MyQ people.
      • plemans's avatar
        are you using any special characters/spaces in the ssid/password? If so, I'd remove them.
