Reply
Embedding Certificates into OpenVPN config
McFast
found solution on another site.
"To embed the certs, simply place the Base64 encoded cert text into the respective <ca> </ca>, <cert> </cert> and <key> </key> tags in your .ovpn config file and comment out the “ca”, “cert” and “key” keywords." (c)
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
client
remote my-server 1194
proto udp
dev tun
persist-key
persist-tun
resolv-retry infinite
nobind
#ca ca.crt
#cert client.crt
#key client.key
comp-lzo
verb 3
<ca>
-----BEGIN CERTIFICATE-----
***Paste CA Cert Text Here***
-----END CERTIFICATE-----
</ca>
<cert>
***Paste Your Cert Text Here***
</cert>
<key>
-----BEGIN PRIVATE KEY-----
***Paste Your Cert Private Key Here***
-----END PRIVATE KEY-----
</key>
after you edit this file you can upload to google drive or icloud and then open one opvn file on your ios device without using itunes
Model: R8500|Nighthawk X8 Tri-Band AC5300 WiFi Router
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Embedding Certificates into OpenVPN config
Thanks for sharing this solution.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 765 views
  • 0 kudos
  • 2 in conversation
Announcements
