Reply
Is a VPN included
Cobalt02
Follower
Is a VPN included
Im not sure if i will need to buy a vpn along with this router or if the router comes with a vpn
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 2
Guru
Re: Is a VPN included
Please post about this here for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Thank you.
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK853 v3.2.18.1/RBK50 v2.7.2.104(WW)
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450(v2.3.2.120) and WNHDE111
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 281 views
  • 0 kudos
  • 2 in conversation
Announcements
