Reply
Issue with openvpn running on NETGEAR Nighthawk X6 R8000 behind telco gateway router
simpleb
I have telco modem/router that connects through PPPoe and it acts as a gateway on 192.168.2.1.  I have connected NETGEAR Nighthawk X6 R8000 on lan1 of the telco router.  Netgear Nighthawk X6 is reachable on 192.168.1.1.  Now the vpn service is running on netgear x6 on port 12974.  When I connect my Mac via Tunnelblick or Viscosity, the IP address on my mac doesn't change to local lan ip address.
This is the log I am getting.  Can someone guide me as to how to set it up properly.  Do I have to do port forwarding from telco router 192.168.2.1 port 12974 to netgear 192.168.1.1 on port 12974?
Log is here:
Feb 22 18:43:05: Viscosity Mac 1.6.1 (1332)
Feb 22 18:43:05: Viscosity OpenVPN Engine Started
Feb 22 18:43:05: Running on Mac OS X 10.11.3
Feb 22 18:43:05: ---------
Feb 22 18:43:05: Checking reachability status of connection...
Feb 22 18:43:07: Connection is reachable. Starting connection attempt.
Feb 22 18:43:09: OpenVPN 2.3.10 x86_64-apple-darwin [SSL (OpenSSL)] [LZO] [PKCS11] [MH] [IPv6] built on Jan 29 2016
Feb 22 18:43:09: library versions: OpenSSL 1.0.2f  28 Jan 2016, LZO 2.09
Feb 22 18:43:10: WARNING: No server certificate verification method has been enabled.  See http://openvpn.net/howto.html#mitm for more info.
Feb 22 18:43:10: UDPv4 link local: [undef]
Feb 22 18:43:10: UDPv4 link remote: [AF_INET]MY_IP:12974
Feb 22 18:43:11: [netgear] Peer Connection Initiated with [AF_INET]MY_IP:12974
Feb 22 18:43:14: OpenVPN ROUTE: OpenVPN needs a gateway parameter for a --route option and no default was specified by either --route-gateway or --ifconfig options
Feb 22 18:43:14: OpenVPN ROUTE: failed to parse/resolve route for host/network: 192.168.1.1
Feb 22 18:43:14: TUN/TAP device /dev/tap0 opened
Feb 22 18:43:15: write to TUN/TAP : Input/output error (code=5)
Feb 22 18:43:15: DHCP enabled on tap interface tap0
Feb 22 18:43:19: Initialization Sequence Completed
Feb 22 18:43:22: DNS mode set to: Split
Feb 22 18:43:22: WARNING: Split DNS is being used however no DNS domains are present. The DNS server/s for this connection may not be used. For more information please see: https://www.sparklabs.com/support/kb/article/warning-split-dns-is-being-used-however-no-dns-domains-...
Any help is greatly appreciated. Thank you.
Message 1 of 4
doraemon
Prodigy
Re: Issue with openvpn running on NETGEAR Nighthawk X6 R8000 behind telco gateway router
Where are you connecting your Mac computer?
Is it behind the NETGEAR or outside network?
gimme dorayaki Smiley Very Happy
Message 2 of 4
simpleb
My mac is connected via mobile hotspot and not connected to netgear home network setup.
Message 3 of 4
JamesGL
Master
Hi simpleb,
You may need to do port forwarding on your telco router as the R8000 is connected to a private network and OpenVPN will not work.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2352 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
