Reply
Loosing internet connection only on 2.4 GHz WiFi Randomly
SteveBea
Follower
My R7000 – Nighthawk AC1900 Smart WiFi Router looses internet connection on 2.4 GHz WiFi randomly, but 5 GHz is still connected.  Any idea why this would happen?
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 2
Guru
Re: Loosing internet connection only on 2.4 GHz WiFi Randomly
How many wireless nieghbors are near buy? What channels are they using?
Using Auto Channel on any radio will cause a loss of connection when the router encounters interference and usually will auto use a different channel. You can use a manual channel on 2.4ghz to help avoid this maybe. Use 1, 6 or 11. However other neighbors may still be using those channels. Let us know.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RAXE50 and R8500(v.158) Router Mode | Switches NG GS105/8 |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2033 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
