rms0867's avatar
rms0867
Follower
Dec 10, 2021
Modem Recommendation
Hello:
I am looking at the following modem CM2050V; however, do not see that it supports the dual frequency band. Specifically, looking for 2.4GHz frequency band to use with smart bulbs. Is there a similar modem available that also provides the dual frequency bands? Please advise.
Best Regards,
Ross
NETGEAR Nighthawk Multi-Gig Cable Modem with Voice CM2050V - for Xfinity Internet & Voice Supports Cable Plans Up to 2.5Gbps 2 Phone Lines DOCSIS 3.1
  • Unfortunately, if I'm not mistaken, there's no NETGEAR gateway that offers DOCSIS 3.1 and a 2.4 GHz band. All seem to be 5 GHz only with 2.5 Gbps WAN ports
    What you can do is get a modem-only device and hook up a router to it that provides 2.4/5 GHz bands
  • FURRYe38's avatar
    The CAX80 has 2.5Gb WAN port and is dual wifi band supporting, 2.4Ghz and 5Ghz and is DOCSIS 3.1
    The C7800 is same accept for the 1Gb WAN port.
  • plemans's avatar
    The CM2050V is a modem only device. It doesn't have wifi or any routing capability.
    If you purchase that modem, you'd need to add your own router to it.
    • microchip8's avatar
      microchip8
      Master
      From reading the OPs question, he's looking for Xfinity-certified devices. Are you guys sure that CAX80 & co support Xfinity?
      • plemans's avatar
        Yes. The cax is supported on Xfinity
