timmyK's avatar
timmyK
NETGEAR c7000v2 slow speed with blinking lights
I have 200 Mbps connection and I get around 120-180 Mbps during the day. At nights, it gets slow. (20-40 Mbps).
These lights are blinking a green light on the router:
  • Download arrow
  • 2.4GHz icon
  • 5 GHz icon
In cable connection page, I see "Downstream Bonded Channels (Partial Service)" but not sure what it means. I've tried restarting the router, but it didn't seem to help much.
Firmware Version
V1.03.03
Startup Procedure
ProcedureStatusComment
Acquire Downstream Channel651000000 HzLocked
Connectivity StateOKOperational
Boot StateOKOperational
SecurityEnabledBPI+
IP Provisioning ModeHonor MDDhonorMdd(4)
ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectables
1LockedQAM25644651000000 Hz-0.5 dBmV39.1 dB1480853
2LockedQAM25624531000000 Hz-0.9 dBmV38 dB46031218
3LockedQAM25625537000000 Hz-0.8 dBmV39.5 dB2332674
4LockedQAM25626543000000 Hz-0.7 dBmV39.5 dB20631254
5LockedQAM25627549000000 Hz-0.8 dBmV39.4 dB1713926
6LockedQAM25628555000000 Hz-0.9 dBmV39.2 dB2434963
7LockedQAM25629561000000 Hz-0.8 dBmV38.1 dB50
8LockedQAM25630567000000 Hz-0.8 dBmV38.8 dB2663993
9LockedQAM25631573000000 Hz-0.8 dBmV39.2 dB1970838
10LockedQAM25632579000000 Hz-0.7 dBmV39.1 dB2352981
11LockedQAM25633585000000 Hz-0.6 dBmV39.1 dB2131904
12LockedQAM25634591000000 Hz-0.6 dBmV38.8 dB2330921
13LockedQAM25635597000000 Hz-0.6 dBmV37.6 dB2986794
14Not LockedUnknown36603000000 Hz0.0 dBmV0.0 dB00
15LockedQAM25637609000000 Hz-0.5 dBmV32.9 dB27153814836048345
16LockedQAM25638615000000 Hz-0.6 dBmV39.5 dB2111865
17LockedQAM25639621000000 Hz-0.8 dBmV39.7 dB00
18LockedQAM25640627000000 Hz-0.8 dBmV38.7 dB00
19LockedQAM25641633000000 Hz-0.8 dBmV37.2 dB00
20LockedQAM25642639000000 Hz-0.5 dBmV39.4 dB00
21LockedQAM25643645000000 Hz-0.4 dBmV39.9 dB00
22LockedQAM25645657000000 Hz-0.7 dBmV39.5 dB00
23LockedQAM25646663000000 Hz-0.7 dBmV39.5 dB00
24LockedQAM25647669000000 Hz-0.6 dBmV39.9 dB00
Upstream Bonded Channels
ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
1LockedATDMA75120 Ksym/sec29200000 Hz51 dBmV
2LockedATDMA55120 Ksym/sec16400000 Hz53 dBmV
3LockedATDMA65120 Ksym/sec22800000 Hz52.5 dBmV
4LockedATDMA85120 Ksym/sec35600000 Hz49.8 dBmV
5Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
6Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
7Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
8Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
Extended Upstream Transmit Power
Enable Extended Upstream Transmit Power
Current System Time:Fri Dec 03 21:50:00 2021
System Up Time:19 days 13:47:28
  • This is the connection page after restarting the router. Speed seems faster now but the lights are still blinking.
    Startup Procedure
    SecurityEnabledBPI+
    1LockedQAM25644651000000 Hz-0.3 dBmV39.7 dB00
    2LockedQAM25624531000000 Hz-0.8 dBmV38.7 dB00
    3LockedQAM25625537000000 Hz-0.6 dBmV40.2 dB00
    4LockedQAM25626543000000 Hz-0.6 dBmV40.1 dB00
    5LockedQAM25627549000000 Hz-0.7 dBmV40.1 dB00
    6LockedQAM25628555000000 Hz-0.7 dBmV39.8 dB00
    7LockedQAM25629561000000 Hz-0.7 dBmV39 dB00
    8LockedQAM25630567000000 Hz-0.7 dBmV39.5 dB00
    9LockedQAM25631573000000 Hz-0.6 dBmV39.9 dB00
    10LockedQAM25632579000000 Hz-0.5 dBmV39.7 dB00
    11LockedQAM25633585000000 Hz-0.4 dBmV39.8 dB00
    12LockedQAM25634591000000 Hz-0.4 dBmV39.4 dB00
    13LockedQAM25635597000000 Hz-0.4 dBmV38.1 dB00
    15LockedQAM25637609000000 Hz-0.4 dBmV33.4 dB519289066
    16LockedQAM25638615000000 Hz-0.4 dBmV40.1 dB00
    17LockedQAM25639621000000 Hz-0.6 dBmV40.5 dB00
    18LockedQAM25640627000000 Hz-0.6 dBmV38.8 dB00
    19LockedQAM25641633000000 Hz-0.6 dBmV38.6 dB00
    20LockedQAM25642639000000 Hz-0.4 dBmV40.2 dB00
    21LockedQAM25643645000000 Hz-0.2 dBmV40.8 dB00
    22LockedQAM25645657000000 Hz-0.5 dBmV40.3 dB00
    23LockedQAM25646663000000 Hz-0.6 dBmV40.3 dB00
    24LockedQAM25647669000000 Hz-0.4 dBmV40.3 dB00
    1LockedATDMA65120 Ksym/sec22800000 Hz52.3 dBmV
    2LockedATDMA55120 Ksym/sec16400000 Hz53.3 dBmV
    3LockedATDMA75120 Ksym/sec29200000 Hz50.8 dBmV
    4LockedATDMA85120 Ksym/sec35600000 Hz50 dBmV
    Current System Time:Fri Dec 03 22:14:49 2021
    System Up Time:00:08:27
    • plemans's avatar
      Are you using an amplifier? Based off the power levels that you have for your downstream, your upstream is pretty high.
      If you have any amplifiers, splitters, or signal attenuators in the line, remove them.
      do you also have the modem event logs? That helps us check long term.
      All rebooting does is clear out the errors. It might help the speeds short term if the modem connects on a different frequency but long term, it isn't going to fix the problem.
      • timmyK's avatar
        timmyK
        plemans Thanks for the reply. I don't have any amplifier setup. I hooked up the ISP cable directly into my router
        Connection seems to be stable now, but the lights on the router are still blinking. (downstream arrow, 2.4ghz, 5 ghz icons).
        Attaching the event logs:(Advanced > Administration > Event Logs)
        TimePriorityDescription
        2021-12-3, 22:13:04Warning (5)MDD message timeout;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.1;CM-VER=3.0;
        1970-1-1, 00:00:45Notice (6)Honoring MDD; IP provisioning mode = IPv6
        1970-1-1, 00:00:40Notice (6)WiFi Interface [wl1] set to Channel 153 (Side-Band Channel:N/A) - Reason:INIT
        1970-1-1, 00:00:40Notice (6)WiFi Interface [wl0] set to Channel 2 (Side-Band Channel:N/A) - Reason:INIT
        1970-1-1, 00:00:37Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
        2021-11-24, 12:22:52Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.1;CM-VER=3.0;
        2021-11-15, 12:35:58Critical (3)SYNC Timing Synchronization failure - Failed to receive MAC SYNC frame within time-out period;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.1;CM-VER=3.0;
        1970-1-1, 00:00:37Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
        2021-11-8, 22:48:10Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.1;CM-VER=3.0;
        1970-1-1, 00:39:09Critical (3)No Ranging Response received - T3 time-out;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0;
        1970-1-1, 00:39:03Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0;
        1970-1-1, 00:38:58Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0;
        1970-1-1, 00:38:56Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0;
        1970-1-1, 00:38:55Critical (3)DHCP failed - DHCP Solicit sent, No DHCP Advertise received;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0;
        1970-1-1, 00:38:07Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0;
        1970-1-1, 00:38:06Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0;
        1970-1-1, 00:38:03Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0;
        1970-1-1, 00:37:24Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0;
        1970-1-1, 00:37:22Critical (3)DHCP failed - DHCP Solicit sent, No DHCP Advertise received;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0;
        1970-1-1, 00:36:35Critical (3)No Ranging Response received - T3 time-out;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0;
        1970-1-1, 00:36:31Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
        1970-1-1, 00:36:29Critical (3)No UCDs Received - Timeout;;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
        1970-1-1, 00:36:12Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
        1970-1-1, 00:36:11Critical (3)No UCDs Received - Timeout;;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
        1970-1-1, 00:35:54Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
        1970-1-1, 00:35:53Critical (3)No UCDs Received - Timeout;;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
        1970-1-1, 00:35:29Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
        1970-1-1, 00:35:28Critical (3)DHCP failed - DHCP Solicit sent, No DHCP Advertise received;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0;
        1970-1-1, 00:34:41Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
        1970-1-1, 00:34:40Critical (3)No UCDs Received - Timeout;;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
        1970-1-1, 00:34:23Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
        1970-1-1, 00:34:22Critical (3)No UCDs Received - Timeout;;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
        1970-1-1, 00:34:05Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0;
        1970-1-1, 00:34:04Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0;
        1970-1-1, 00:34:03Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0;
        1970-1-1, 00:34:01Critical (3)DHCP failed - DHCP Solicit sent, No DHCP Advertise received;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0;
        1970-1-1, 00:33:14Critical (3)No Ranging Response received - T3 time-out;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0;
        1970-1-1, 00:33:08Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0;
        1970-1-1, 00:33:08Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0;
        1970-1-1, 00:33:06Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0;
        And here is the logs (Advanced > Administration > Logs)
        I was very concerned about DoS attack at first, but then read online that it's a false alarm due to iPhone or iPad devices.
        https://community.netgear.com/t5/Cable-Modems-Routers/DoS-attack-Teardrop-or-derivative-Ping-of-Death-strange-IPv6/m-p/2051922/highlight/true#M30355
        admin login failure] from source 192.168.0.211Mon Dec 06 13:01:03 20210.0.0.0:0192.168.0.21:0
        [DoS attack: Ping Of Death] from 73.1.0.80, port 03Mon Dec 06 12:49:22 2021232.215.176.155:073.1.0.80:0
        [DoS attack: Teardrop or derivative] from 73.1.0.80, port 01Mon Dec 06 12:49:20 2021232.215.176.155:073.1.0.80:0
        [DoS attack: Ping Of Death] from 73.1.0.80, port 02Mon Dec 06 12:48:36 2021232.215.176.155:073.1.0.80:0
        [DoS attack: Teardrop or derivative] from 73.1.0.80, port 02Mon Dec 06 12:48:35 2021232.215.176.155:073.1.0.80:0
        [DoS attack: Ping Of Death] from 73.1.0.80, port 08Mon Dec 06 12:46:33 2021232.215.176.155:073.1.0.80:0
