Reply
Netgear AC1900 R7000 Nighthawk Router
herzogdl
In the advanced set up features on my netgear AC1900 R7000 router, the remote management feature is greyed out. Does this indicate that the remote management feature in my router is disabled?
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 2
Retired_Member
Not applicable
Re: Netgear AC1900 R7000 Nighthawk Router
It means you're using a mode other than router, any mode other than router disables the routing function and DHCP server.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1695 views
  • 0 kudos
  • 2 in conversation
Announcements
