UsualNoise
Sep 20, 2022Aspirant
Nighthawk R6700v3 maximum wired speed less than cable modem
I've seen several similar threads stating that a firmware issue exists that prevents reaching maximum available speeds, so let me know if there is anything I can do here.
I have the current firmware installed (1.0.4.128_10.0.104) on an R6700v3 router. The problem seems obvious:
1) Connecting my laptop directly to the cable modem port gives my ~220 Mbps download via speedtest.net (I pay for 200).
2) Connecting my laptop directly to one of the ethernet ports on my Nighthawk R6700v3 gives me 150-170 Mbps.
I was considering bumping up my internet speed but if the router won't support it then that would be pointless.
I've powered off and restarted, I've never used QOS (downstream and upstream boxes are unchecked, both WMM boxes are checked), let me know if there is anything other than replacing this router that will fix it. Thanks!
Edited to add: I see a common suggestion is factory resetting, so I will try that when I'm off work. Just seeing if there is any other solution as that seems like a pretty non-user-friendly approach.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Try a factory reset and walk thru the setup wizard. Be sure to NOT enabled Armor, Access Controls, Circle, QOS or Traffic Meter.
- UsualNoiseAspirant
Thanks for responding!
Modem is my own, Arris Surfboard SB-8200. I'm 99% sure the cord is not the problem as I only use Cat 5e or better, but I'll swap in the cord I got 220 Mbps on my laptop just in case. Otherwise factory reset will be the next step.
đ
