Reply
Nighthawk R7800 Disconnecting
Mjhahn28
Follower
Ok so i work for my local ISP (Spectrum) i am an avid gamer and like changing my setup around. However a few months back i moved my set up and started having this issue. Everyday i will need to reset my router for anything hardwired to be connected (Tvs, PS4) however my Xbox 1 does not do this. I will turn my Ps4 on and it will say please connect i then restart my router and it connects right up... What am i missing? Ive reset the router to defualt and everything is up to date
Message 1 of 2
DarrenM
NETGEAR Moderator
Re: Nighthawk R7800 Disconnecting
The modem and router could be having issues have you tried a new cord between the 2? also did you move outlets your modem is on? If so that outlet may not be tuned for the modem.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 186 views
  • 0 kudos
  • 2 in conversation
Announcements
