Reply
Nighthawk X4 R7500 V1.0.0.110 - Cannot save Device Priority settings
CalmDownMonkey
I have Dynamic QoS enabled.
Ever since upgrading the firmware, I cannot change device priority from the default value of "low".
If I click "Edit", change the value to "High", then "Save", it simply reverts to low.
Factory resetting - didn't fix.
Different browsers - didn't fix.
Does anyone have a solution?
Model: R7500|Nighthawk X4 AC2350 Smart WiFi Router
Message 1 of 2
CalmDownMonkey
Re: Nighthawk X4 R7500 V1.0.0.110 - Cannot save Device Priority settings
Reverting to 1.0.0.76 seems to be the only cure... instantly starts working again.
How do they manage to break these features in subsequent releases of firmware? Aren't new releases meant to fix things?
I recommend against upgrading to 1.0.0.110 on the R7500... just live with the hideously slow web UI, at least the features actually work.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 272 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 6E
