Reply
Nighthawk x10 (R9000) 802.11ac
Marck01
Trying to connect a mid 2013 MacBook Air to Nighthawk X10 (R9000) using 5 GHz and 802.11ac, however it only connects thru 802.11n.. anyone having the same issue?
Note: I've the latest router firmware version (V1.0.2.30)
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 6
Guru
Re: Nighthawk x10 (R9000) 802.11ac
Does the 2013 Mac support AC modes?
What connection rate speeds are you seening in OSX?
What security mode do you have set? Try WPA2 and AES only.
Try a manual channel on 5Ghz
Disable MU-MIMO.
My Setup Internet Cable 1000↓/50↑ CAX80 Mode Mode | ISP SparkLight | Wifi Router Orbi CBR752 v4.6.7.7(Gateway Mode), Wired BackhaulSwitches Netgear GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.7.5(AP) & RBK752 v4.6.7.5, RBK50(v23), SXK30(v110), R7000(v34), R7800(v84), R7960P(v84), RAXE500(v78), EX7500/EX7700, GS308v3 and WNHDE111
Testing
Message 2 of 6
Marck01
Thanks for your reply FURRYNUTZ
Yes this 2013 MacBook Air supports AC. Right now I'm getting 200 Mbps upload/download and my security mode is WPA-PSK[TKIP]+WPA2-PSK [AES].
Message 3 of 6
Guru
Testing
Message 4 of 6
Marck01
Tried "WPA2 and AES only" but didn't work. Probably is this old MacBook Air.
Message 5 of 6
Guru
Try WPA and TPIK and see...
Testing
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2788 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
