Reply
Phone Wifi Switches ghz w/R7000
timstack
Apprentice
I'm using 2 separate names for 2.4ghz & 5ghz. When I leave the house my galaxy s8+ is using the 5ghz band but when I return it's using 2.4ghz band with my R7000. Can someone tell me why? Using. 88 version. Thanks
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 5
Guru
Re: Phone Wifi Switches ghz w/R7000
You've saved both names to  your phone.
2.4ghz broadcasts further than 5ghz. So its the first signal it picks up.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 5
timstack
Apprentice
Can I make.my phone only use the 5ghz wifi? Or is there a setting in R7000?
Message 3 of 5
Guru
Some android devices have the option to prefer 5ghz signals. Or you can just go in and forget the ssid for the 2.4ghz network.
Message 4 of 5
It is usually your phone that decides which wifi source to use.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 488 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
