Reply
R7000 NTP Issues
mikes603
R7000 NTP Issues
R7000 V1.0.9.88_10.2.88
Wont sync time. Log reports:
[OPENVPN] NTP sync time failed. Get correct system time then reconnect. Thursday, Jan 01,2015 00:00:33
Tried a factory reset to no avail. Tried us.pool.ntp.org. Doesnt work either.
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 5
Re: R7000 NTP Issues
Greetings,
Please downgrade your FW to v1.0.9.42, perform a set up from scratch and retest.
~Comcast 1 Gbps/50 Mbps SB8200 > R8000P
~R8000P FW:1.4.1.68 ~R7000 FW:1.0.9.42
~R6400 FW:1.0.1.52 ~Orbi-AC3000 FW:2.5.1.8
~EX3700 FW:1.0.0.84
Message 2 of 5
mikes603
@shadowsports wrote:
Greetings,
Can I upgrade back to V1.0.9.88_10.2.88 once I do this?
Message 3 of 5
additude
Virtuoso
Yes you can.
Message 4 of 5
labatt
Prodigy
Greetings,
Yes you can, BUT you may also get your problem back. The .88 is not the best firmware Netgear has produced. I would do as suggested of going back to .42 and stay there until Netgear get their firmware engineering fixed, if that is possible for them to do.
Modem CM2050V
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 498 views
  • 0 kudos
  • 4 in conversation
Announcements
