- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000: UPNP Renderer not visible when connected via WiFi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all,
I use the R7000 as a router and have the problem that my UPNP renderer (Denon DNP-F109) is not visible if connected via WiFi (via Ethernet, everything works fine).
Can anybody give me a hint what to do here?
I have switched on DHCP and UPNP in the configuration. All UPNP devices (renderer/server/controller) are in the same local 192.168.* network.
Many thanks
Stefan
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Stefan,
Please perform a reset on the device and check again if still the same problem.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000: UPNP Renderer not visible when connected via WiFi
Hi Slapi2000,
What is the IP address of your renderer?
Can you ping the IP address?
Do you have other devices working with wireless?
What is the firmware version of the router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
IP address: 192.168.1.2 (static assignment)
Ping: yes
Other devices: yes, few mobile phones/tablets (none of which with any UPNP role).
Firmware: V1.0.6.28_1.1.83 (the bug is there since a number of releases - I have been hoping since a while this gets fixed at some point)
Best regards,
Stefan
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Stefan,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you tried address reservations?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
having tested for a while, I can confirm that the router reset did solve the issue. Many thanks for the hint.
Best regards,
Stefan
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi slapi2000,
Glad to know it works now.
