Reply
R7800 PSN IP ban
Ghaspetti
R7800 PSN IP ban
Hello
I've just recently picked up the R7800 and prior to this I was using isp provided router and never had an issue but with this new router I've been IP banned twice from the PlayStation Network. I'm wondering if there's a setting in the router that can be causing it.
Thanks in advance
Message 1 of 5
JamesGL
Master
Re: R7800 PSN IP ban
Hi Ghaspetti,
There is no option on the router for it. Do you happen to know why you are getting banned from PlayStation Network?
Message 2 of 5
JamesGL
Master
Hi Ghaspetti,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 3 of 5
Ghaspetti
No it's still happening. They won't tell me anything other than that I'm violating the terms. I have to force a IP address change every time by changing the Mac address. That will fix it for a little while the my IP gets banned again.
Message 4 of 5
JamesGL
Master
Hi Ghaspetti,
They should explain the reason or which terms and conditions you have violated. If they can't then I would recommend changing ISP.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2207 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
