Reply
R8000 IPV6 DNS BLANK
Retired_Member
Not applicable
Message 1 of 2
Willpower
Re: R8000 IPV6 DNS BLANK
Because you checked to use automatically assigned numbers (to the left).  The boxes you pointed out only need to be filled out if you choose manual configuration.
Why the R7000 fills them out with automatic configuration is a complete mystery -  unless it simply keeps previously entered numbers for future use (in case you want to revert back to manual configuration again).
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1427 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
