Reply
R8500 CTF with PPPoE and VLAN Tagging
Celeron655
Follower
Hi,
Can someone please confirm if CTF (Cut through forwarding) is enabled with R8500 with PPPoE and Vlan Tagging On?
I am having issues and not getting over 600/200 on a 900/400 connection.
Thanks
Model: R8500|Nighthawk X8 Tri-Band AC5300 WiFi Router
Message 1 of 2
avtella
Prodigy
Re: R8500 CTF with PPPoE and VLAN Tagging
It should have CTF enabled as that PPPoE CTF incompatibility was fixed by Broadcom a while back according to RMerlin a custom firmware dev.
If CTF was not enabled I doubt you’d get to 600 Mbps, it would be more like 300-450 Mbps without it if my memory is correct from some discussions a year or two back.
As Case 850 said try testing without VLAN Tagging by setting your modem to do it with a Transparent Bridge w/VLAN201 tag on the modem side.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 589 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
