Reply
R9000 AD
Itai92
R9000 AD
I’ve been looking into the R9000 router. Is the band AD useless right now since we don’t have any ad WiFi clients? Would it be better to get a model lower since the WIFi speed would be fast since we use 2.4Ghz and 5 GHz
Message 1 of 3
Guru
Re: R9000 AD
If you don't have any AD supporting devices then the router would probably not be a wise choice. If your looking to get some AD supporting devices, I presume there are not alot currently, then at some point maybe AD router would be ok.
I would stick with and AC class wifi router.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)> RBK953(v6.0.3.68) & XR450(v130)
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, and WNHDE111
Message 2 of 3
Itai92
Re: R9000 AD
Thanks.
there is 8 people living with me at the house. There's a lot of devices that are on the internet. I'm looking into the x8.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 473 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
