Oterwill's avatar
Oterwill
R9000 BTTV IGMP Configurarion
I have an R9000 and connect it straight to the openreach modem on the wall. I have FTTP from BT and I have BTTV. in my WAN settings I do have “ support british telecom (bt) igmp proxying.” And all my IPTV channels work, but the next day or two I get IPC6023 error, and I have to Untick the setting and apply and then retick apply and it works again.
Is there anyway for it to work constantly, rather than having to log into the router and reset the setting every other day?? It’s a work around but an annoying one.
  • FURRYe38's avatar
    • Oterwill's avatar
      Oterwill
      V1.0.5.38
      Yes. Done a reset on it and started from scratch when it wasn’t working at first.
      • FURRYe38's avatar
        Had this worked before while using any other prior versions of FW or is this the first time this has started?
