Orbi WiFi 7 RBE973
Reply
RBR20 Orbi 34
Randycsmith1953
Follower
RBR20 Orbi 34
I apparently have forgotten the password to my router.  I have all of my passwords saved in a password-protected file but the password does not work.  I recently purchased a smart bed and trying to connect it to my network but my password does not work.  And I cannot change the password without first entering my password which I do not have.
Perhaps obviously I am not tech savvy.  Any suggestions would be appreciated.
Model: CBR40|Orbi AC2200 Tri-band WiFi Cable Modem Router
Message 1 of 3
Guru
Re: RBR20 Orbi 34
Password to the wifi?
Password to log into the gui? Which did you loose?
You can try using the password recovery if its the admin password (and you setup password recovery)
How do I recover my NETGEAR admin password using the password recovery feature? | Answer | NETGEAR S...
Message 2 of 3
Jessica56
Re: RBR20 Orbi 34
Orbi system can simultaneously support up to 250 clients under most conditions. If your household has users who use a lot of bandwidth for activities like HD video streaming and online gaming,
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 744 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
