- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
REDUCED WIFI SPEED with NETGEAR R7500
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I am having troubles with my NETGEAR R7500. I upgraded to 110mps speed by am only getting speeds of around 54mps.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: REDUCED WIFI SPEED with NETGEAR R7500
What kind of device are you using? Smartphone? Computer? If it's a computer, what is the model # of the Wi-Fi adapter?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I have Wide Open West internet with 110mpbs
My lap top has Qualcomm Atheros AR956x wireless adapter. When i connect using cat5 cable i get extemely high speeds on test but i keep dropping off interent. As for the two computers, they have USB Realtek RTL8192CU 802.11N adapters.
Thank you for your assistance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
It's hard to find information about the Atheros AR956x, but it appears to be a single band (2.4 GHz only), single stream 802.11n Wi-Fi adapter. When using 20 MHz wide channels (very common with 2.4 GHz Wi-Fi when other Wi-Fi networks are present), the maximum link speed possible is 72.2 Mbps. Real world throughput will probably be in the 25 to 35 Mbps range. If no other Wi-Fi networks are present, then you may be able to use 40 MHz channels and a link speed of 150 Mbps. Real world throughput will be 50% of that or less (75 Mbps or less). But I wouldn't count on being able to use 40 MHz channels with 2.4 GHz Wi-Fi.
The Realtek RTL8192CU adapters are dual band (2.4 GHz and 5 GHz), dual stream 802.11n Wi-Fi adapters. These should be able to connect at a link speed of 300 Mbps at 5 GHz. Again, real world throughput will be 50% or less (150 Mbps or less).
With respect to the R7500, you will want to make sure that WMM is enabled. Without it, Wi-Fi will slow to a crawl. The other QoS functions, like upstream and downstream QoS, can remain off. Since you have pretty fast Internet service (120 Mbps), you probably won't benefit from QoS, so I recommend that you leave upstream and downstream QoS off, but feel free to experiment.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thank you very much for you imput! I enabled WMM and this has increased speed! Do you think going to a more powerful AC adapter on my computers (and laptop) would be beneficial? I am looking at the AC1200 from NETGEAR.
Also, on my laptop,when i plug cat5 cable into router, i get blazing speeds but my interenet keeps dropping off. Any suggestions?
Thank you kindly!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
As for your Internet connection, more information is needed to diagnose it. You may need to log into your router as well as your modem and do some sleuthing. Is the connection dropping from the router or is the modem also losing the connection? Look at the logs of both devices and look for signs of the Internet connection dropping. There might be a reason given.
You may also want to try a different Ethernet cable. It could be bad. Also try a different LAN port on the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: REDUCED WIFI SPEED with NETGEAR R7500 - connection drops when hard wired to router.
My wireless speeds are UP! My only problem is when i am wired directly from my laptop to the router my connection drops every few minutes. I have to unplug the cat5 cable from my laptop and then plug back in. Any suggestions for this?
Thank you,
DD
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi @Duckdive,
Welcome to Community!
To isolate the problem, connect a different computer wired to the router and check if it has the same problem. Try all ports of the router and use a different cable. If it only happens on one computer, you may need to update the LAN card of that computer.
JamesGL
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
James,
Sorry for my delayed response.
I have tried other computers hardwired to the router. They do not have problems with dropping off.
When i bring the same laptop to my office it never drops off on that network. Only on my home router, so i do not believe it is my LAN card.
Any other suggestions?
Thank you kindly!
RIchard
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
