Orbi WiFi 7 RBE973
Reply
Stream Smart TV audio to LAN speakers
guatelize
I have a Samsung Smart TV ue48h6200 & Sony Airplay/Lan/audio Jack Speakers Sony RDP-X700IP (1x) & SA-N310 (2x) and wish to improve audio from my TV to these speakers. Is it possible to connect them all with my the Netgear Nighthawk R7500-100PES X4 AC2350 to stream the audio from my TV to these speakers ?
Thanks for your help.
Best regards
Olivier
Message 1 of 4
Accepted Solutions
TheEther
Guru
Re: Stream Smart TV audio to LAN speakers
You should do your own research to confirm the following. It looks like Samsung Smart TV's can send sound over Wi-Fi, but only to Samsung Multiroom compatible speakers. I think you are out of luck with your streaming to Sony speakers. Source: Samsung Smart TV manual.
Why don't you connect the audio out of the TV to the audio in of the speakers using an audio cable?
Message 2 of 4
All Replies
TheEther
Guru
Message 2 of 4
guatelize
Thanks for your reply, I will try your suggestion, but I wanted to avoid the quantity of wires.
Regards
Olivier
Message 3 of 4
netwrks
Master
There are also bluetooth adapters that can trun wired speaker into bluetooth speakers. If you goolge bluetooth speaker adapters you should be able to find some..
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 7028 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
