Orbi WiFi 7 RBE973
Reply
UPNP broken in Netgear R7800 on firmware 1.0.2.68
sachb
Tutor
Hello Netgear community, hope you're all doing well.
I'm writing this post just acknowledge that, as per my prior experience with the firmware (V1.0.2.68), the Upnp isn't functioning, and I would always see the yellow light in Bitcomet.
My internet connection is PPPOE with username & password.
It works now, after reverting back to the older version which is V1.0.2.62. Please can others confirm on this issue. It would be helpful if the developers could fix the issue which persists.
Thank you
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 25
Accepted Solutions
dzesio
Tutor
Re: UPNP broken in Netgear R7800 on firmware 1.0.2.68
I was mistaken. In firmware V1.0.2.78 UPNP works 🙂
Message 17 of 25
All Replies
Kronvrak
Guide
Often it feels better if others have it as bad or worse than yourself.
The latest version 1.0.4.46 for R8000 also have UNPN broken, not a word from Netgear even if a huge number of users have reported this for the last 5 months. They have not even acknowledge that it doesn’t work.
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 2 of 25
schumaku
Guru
@Christian_R  please.
Message 3 of 25
fmiranda
You are luck, I'm running firmware  V1.0.2.62 and uPNP is not working!!!
I tried V1.0.2.68 and same issue! How can Netgear miss the ball on such a good wifi router?
My uPNP stay always clear, can't connect to games online, can't have my NAS to expose services to outside.
Message 4 of 25
microchip8
Master
UPNP is often a risk. Better setup your program to use a specific port and do a port forwarding on the router using that port and IP reserved DHCP address on the computer you run the program
Message 5 of 25
labatt
Mentor
 If they acknowledge the firmware is broken then folks would expect them to fix it. This way they can sit back and ignore since they do not acknowledge an issue. There are firmware issues that are over a year old that plagued my r8000 when I had it and the issues are still present. I would not hold my breath as it seems that there is no testing of firmware for bug fixes before posting. On top of that, lots of lucky folks cannot use features they bought the router for, because in Negear's infinite wisdom they added Armor and had to remove features to make room for Armor. Not the company I remember. My Netgear modem works fine, but I moved on for a router.
Message 6 of 25
sachb
Tutor
Any update on this?  I'm still using the  1.0.2.62 for months now, and seems to be rock stable but would like to have a new firmware for security fixes if persists or other enhancements or improvements & new features.
Netgear isn't planning to release another firmware with a working upnp?
Message 7 of 25
sachb
Tutor
Check whether your upnp service is enabled on the services.msc if you're running windows. I can confirm the upnp is working on 1.0.2.62 but not on the 1.0.2.68
Message 8 of 25
fmiranda
Upnp is working on 1.0.2.62! But not working on 1.0.2.68!
Netgear, get your **bleep** together and release a new firmware update that fixes the upnp and provided the latest security updates.
Message 9 of 25
munkong
For me, DLNA (uPnP) was working on 1.0.2.68. Then I turned it off, and then turned it back on. From since then, uPnP stopped working - all my videos cannot be streamed. Not only that, SMB access to videos also stopped working for my iPhone and iPad, even though SMB is still working on my macOS. Tried a lot of reboots / configs but can't work. Downgraded to 1.0.2.62 and every video on uPnP and SMB streamed well. Upgraded back to 1.0.2.68 and every video just stopped streaming again. I am now on 1.0.2.62..
Message 10 of 25
fmiranda
Hello Netgear developers, can you please address this issues with the 1.0.2.68 firmware breaking the upnp support of the router?
Why we don't have a single Netgear community moderator checking this post? it's been months and no answer???????
Come'n Netgear, fix the issue!!!!
Message 11 of 25
sachb
Tutor
They've released a new Firmware 1.0.2.74, will try soon & post back or if someone can try & post the ressults. Hope the upnp is working on the version 1.0.2.74
Message 12 of 25
munkong
Have you tried and saw if upnp is working on version 1.0.2.74?
Message 13 of 25
Ilias83
Guide
No, unfortunately they didn't fix that one.
I upgraded to 1.0.2.74 yesterday and rolled back to 1.0.2.62
Message 14 of 25
fmiranda
Guys,
I gave up on Netgear wifi routers. I moved on to Ubiquiti hardware, they have many options and Price ranges. I highly recommend that.
Message 15 of 25
dzesio
Tutor
firmware V1.0.2.78
UPNP not working
my Synology server does not recognize as UPNP router.
If you have deactivated UPNP for safety reasons, please delete this function.
Message 16 of 25
dzesio
Tutor
Message 17 of 25
munkong
I wonder what settings are different..
Message 18 of 25
sachb
Tutor
Oh ya, they did fix the UPNP on version 1.0.2.78, I can confirm it. Bitcomet is green again, I wonder what happened in version .74 & .68?
Message 19 of 25
munkong
1.0.2.68 does not work for me. 1.0.2.62 works. I have not tested 1.0.2.78. Have you?
Message 20 of 25
sachb
Tutor
Yes, I just now updated to 1.0.2.78, they've finally fixed the UPNP. You can test it on Bitcomet app or any of the online website tool.
Message 21 of 25
munkong
ok, I will test it by today or tomorrow and give a reply here.
Message 22 of 25
munkong
Hi, I tried the latest firmware 1.0.2.78. uPnP cannot work for me. I used vlc player to try accessing video files. Turned off and on uPnP, still cannot. Once I downgraded back to 1.0.62, uPnP worked not only perfectly, but very fast.
Message 23 of 25
dzesio
Tutor
Unfortunately the situation repeats itself in firmware 1.0.2.90
UPNP has stopped working again.
Is there any way to get a port forwarding list in place quickly? I have about 80 items to enter.
Message 24 of 25
Guru
What devices do you have connected?
How is the router configured?
How are you determining that uPnP is failing?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
You can try Voxels FW.
Message 25 of 25
Top Contributors
Discussion stats
  • 24 replies
  • 6328 views
  • 2 kudos
  • 10 in conversation
Announcements
Orbi WiFi 7
