Orbi WiFi 7 RBE973
Reply
USB drive shows only one partition
OldDuffer
Just thrown away my hideous BT Home Hub 3 and replaced it with a Netgear D6400, latest firmware installed (V1.0.0.56_1.0.56).  All seems well except for the USB-connected 2TB Western Digital drive I've been using for a number of years (if I recall correctly it worked with my previous Netgear ADSL device too).
Simple problem: there are three partitions on the drive but I can only see one.  Wasn't a problem for the crappy BT device.
I've seen some posts suggesting it may be a genuine issue with the Netgear devices, ie. there don't appear to be successful resolutions to this missing configuration.
Can I configure my way out of this or do I have to combine all of the partitions into one?
Thanks,
Keith
Message 1 of 12
Accepted Solutions
Re: USB drive shows only one partition
Glad to have been usefull to you.
Kudos appriciated.
Have a great day!
Message 12 of 12
All Replies
What type of partitions the HDD has?
Message 2 of 12
OldDuffer
Hi,
There's a primary partition and two logical partitions, all formatted as FAT32.
Thanks,
Keith
Message 3 of 12
The only answer I am thinking about is that the device is booting only on one partition and on the primary and do not recognize the logical ones.
I may be wrong!
Message 4 of 12
OldDuffer
It's not a boot device, it's only used for storage. I can only see the primary partition through ReadyShare, not the logical ones.
Message 5 of 12
I know this is not a boot device but the way the unit is booting on the drive it only sees the first partition and blind to the other logical ones.
Message 6 of 12
OldDuffer
Thanks for your comments and interest, but I'm not sure where this is going: I know it only sees the primary, that's the problem.
The question is whether more recent Netgear kit can or should recognise multiple partitions on a USB drive? My old ADSL router could (I think it was a DGND3300) and the lousy BT kit could ... why not the D6400 which is way superior in all other respects.
Thanks.
Message 7 of 12
Do you have an USB key, make an experiment doing 2 partitons and see if the 2 are recognized or only one?
Message 8 of 12
OldDuffer
That was a really good suggestion. I eventually got a USB thumb drive set up with two partitions and ReadyShare does actually see both: fantastic news!
I think the two non-primary partitions may be Extended rather than Logical (they're reported as logical by the EaseUS tool I'm using). I may be able to convert from Extended to Logical in which case job done! Let's see.
Thanks.
Message 9 of 12
I am glad that I could eventually helped you to partially solve your issue!
Thumbs up!!
Message 10 of 12
OldDuffer
Success!  But I'm not 100% sure why.
Having spent Sunday backing up the three partitions on the USB drive, last night I converted one of the extended partitions to logical in EaseUS Partition Manager and confirmed that the content was as I expected on a desktop.  I then plugged the drive into the D6400, expecting to see the primary and one of the non-primary partitions ... and lo! ... I could see all three.
I'm currently running with an apparent mix of three types of partition but it seems to be quite happy, I have the primary, a logical and the unconverted extended partition.  I don't intend to tinker further, it's working for my purposes.
I reckon this is solved: thanks for your help!
Keith
Message 11 of 12
Kudos appriciated.
Have a great day!
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 6713 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
