Orbi WiFi 7 RBE973
Reply
Unable to get r7000 into reset mode to re-flash bios to OEM from DD-WRT
thedogger35
Guide
Have a r7000-AC1700 that curently has DD_WRT on it and I am trying to flash it back to the original OEM initial release of Netgear BIOS
I am unable to get the R7000/AC1900 to go into reset to allow for a TFTP file transfer to flash the firmware
R7000 Firmware Version 1.0.0.96
also have tried others
When trying from the GUI and using the initial release version it fails so I am trying to force the flash
I have watched several videos and methods on how to get into reset mode but none work
1- Hold the reset for 30sec and wait for the power light to start to flash - just stick in a reboot cycle
2- Hold the reset for 30sec then pull power wait 30sec and power back - same result
With the DD-WRT I can use the router without issue, just need to get back to OEM OS to upgrade and flash to Tomato
Any thoughts?
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 13
Accepted Solutions
thedogger35
Guide
Re: Unable to get r7000 into reset mode to re-flash bios to OEM from DD-WRT
Finially Success
.\nmrpflash -i net2 -f R7000-V1.0.0.96_1.0.15.chk
Advertising NMRP server on net2 ... -
Received TFTP_UL_REQ while waiting for CONF_REQ!
Received upload request without filename.
Uploading R7000-V1.0.0.96_1.0.15.chk ... OK
Waiting for remote to respond.
Received keep-alive request (16).
Remote finished. Closing connection.
Reboot your device now.
PS C:\Users\Dogger35\Desktop\dd-wrtv2\New folder> ipconfig
Windows IP Configuration
Ethernet adapter Npcap Loopback Adapter:
Connection-specific DNS Suffix . :
Autoconfiguration IPv4 Address. . : 169.254.87.4
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :
Ethernet adapter Ethernet:
IPv4 Address. . . . . . . . . . . : 192.168.1.10
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
PS C:\Users\Dogger35\Desktop\dd-wrtv2\New folder> ping 192.168.1.1 -t
Message 11 of 13
All Replies
Guru
I'd ask on the dd-wrt forum. They're the experts on their firmware and how best to remove it without bricking your device.
Message 2 of 13
labatt
Mentor
Since there is no back to stock firmware listed this may mean that Brainslayer has added code to reinstall Netgear firmware. Have you tried to install a Netgear firmware?
2 Years ago I wound up having to use a serial to USB cable to reinstall Netgear firmware. I never got tftp to work to get back to Netgear. Yes I have successfully used tftp when the firmware was Netgear, to answer those that ask have you ever successffully done a tftp. 😉
Message 3 of 13
thedogger35
Guide
Thanks for the response, I get posting on the dd-wrt forum, but the issue is that the r7000 will not go into reset mode.I cant get the power light to blink orange.
That is the real issue.
Message 4 of 13
Guru
have you tried nmrpflash?
https://github.com/jclehner/nmrpflash
Message 5 of 13
thedogger35
Guide
Thanks but I dont see a D/L for Win10 64-bit
Dont have a MAC or Linux to run other version
Model: R7000|AC1900 Smart WIFI Router
Message 6 of 13
Guru
the 32bit program will run on your 64bit windows machine.
Message 7 of 13
thedogger35
Guide
Ya right now bird dogging this error
"The program can't start because wpcap.dll is missing" (Windows)"
Installed ncap and still get the dam error trying to run the exe
Message 8 of 13
Guru
tried it myself on my windows 10 64bit computer and was able to use it.
Not sure exactly what you're doing wrong.
Message 9 of 13
thedogger35
Guide
Got it up and running, Ill update how it goes...my hope is that flashing this back into OEM firware then to advanced tomato I moght be able to get ride of the issue that netgear does not want to admit to with the G5 wireless always failing
Thought that I resolved it with the dd-wrt but issue persisted, has to be hardware. If the Tomato does nto fix it then its going in the trash
Message 10 of 13
thedogger35
Guide
Finially Success
Message 11 of 13
Guru
glad to hear you got it working!
Message 12 of 13
thedogger35
Guide
OH its far from fixed, now have to see if the Advanced Tomato help with thnotoriously disapearring 5GWiFi issue that Netgear fails to acknowledge and either fix or admit that there is a hardware issue with the R7000
Message 13 of 13
Top Contributors
Discussion stats
  • 12 replies
  • 3139 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
