Discussion stats
  • 0 replies
  • 61 views
  • 0 kudos
  • 1 in conversation
Announcements
Top Contributors
Reply
Highlighted
Follower
Upnp problem, Open NAT fail
My problem was getting Open NAT. For around 4-7 months since I bought the router, I only experienced this one issue, I tried many times factory reset, or doing enable and disable cycles on upnp, I've checked all around in the firmware to see if it was something blocking upnp like port forwarding, DMZ, but all were disabled. My old router worked perfect with upnp. I would really appreciate if you can help me on this obe
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 1
