Orbi WiFi 7 RBE973
Reply
VoIP phone cannot initiate outgoing call with R7000 Router Installed
mtlviya
Tutor
I have had my Nighthawk R7000 Router installed and set up, it works fine except my SIP-based VoIP phone cannot make any outgoing calls anymore (it can still receive calls properly). The error code I got is SIP 400 “Bad Request”, which means the request could not be understood due to malformed syntax (RFC3261). In other words, the outgoing request has been modified by the R7000 router, so the VoIP ISP server could not understand the request anymore, the call initiation request is declined.
The VoIP ADA I use is Obihai OBI202, which works perfectly with my VoIP ISP server before Nighthawk R7000 Router installation (now the OBI202 ADA has to go through R7000 router to connect to the internet).
Could someone tell me how to configure the router to make sure the outgoing SIP request will not be modified?
Here is the additional information:
Nighthawk R7000
Firmware Version  V1.0.7.12_1.2.5
OS - Windows R7 Enterprise
OBI202 goes through R7000 router to connect to internet.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 12
Accepted Solutions
JamesGL
Master
Re: VoIP phone cannot initiate outgoing call with R7000 Router Installed
Hi mtlviya,
Set the VoIP's IP in DMZ mode.
Message 7 of 12
All Replies
TheEther
Guru
This is just a shot but try playing around with the SIP ALG toggle in WAN Setup.
Message 2 of 12
mtlviya
Tutor
After disabling SIP ALG in WAN setup, it works now. Thanks for your help.
Message 3 of 12
mtlviya
Tutor
After selecting the "Disable SIP ALG" option in the WAN setting, the outgoing calls from VoIP phone works. But the incoming calls to VoIP phone only partially work, it only works right after the VoIP phone generates an outgoing call; after 5 minutes, the VoIP call is not reachable anymore. Any call to this VoIP phone will get an announcement "The subscriber you are calling is not available". Are there any other settings I need to adjust?
Message 4 of 12
JamesGL
Master
Hi mtlviya,
Check this firmware version of the router.
https://kb.netgear.com/000039940/R7000-Firmware-Version-1-0-9-6
Message 5 of 12
mtlviya
Tutor
Hi JamesGL,
The firmware I have is exact the "Firmware Version V1.0.9.6_1.2.19".
I encountered this problem on this version of this firmware.
Message 6 of 12
JamesGL
Master
Hi mtlviya,
Message 7 of 12
JamesGL
Master
Hi mtlviya,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 8 of 12
mtlviya
Tutor
 Hi JamesGL,
Thanks for your prompt help.
After configuring the VoIP phone as the Default DMZ Server, both the incoming calls to the VoIP phone and outgoing calls from the VoIP phone work now.
I will do more tests in the several upcoming days to see if it keeps working and if it works in other scenarios, I will have the results posted.
According to the R7000 User Manual (May of 2017), page 119, as below.
"DMZ servers pose a security risk. A computer designated as the default DMZ server loses much of the protection of the firewall and is exposed to exploits from the Internet. If compromised, the DMZ server computer can be used to attack other computers on your network"
Since what I have exposed is just a VoIP phone, I guess the risk is very limited, right?
Thanks again for your help.
Message 9 of 12
JamesGL
Master
Hi mtlviya,
Yes that is correct since this is not a computer that can be used to access local devices.
Message 10 of 12
mtlviya
Tutor
Hi JamesGL,
I have tested the VoIP phone for two more days, everything works fine.
Message 11 of 12
JamesGL
Master
Hi mtlviya,
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 11487 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
