Reply
WIFI not showing
McSkrillz
WIFI not showing
I just got a R7900P.  Connected router and downloaded netgear genie.  Internet works when something is connected via ethernet cable from router, but my WIFI isn't working.  Was working the day before, and then just stopped.  Restarted modem, turned wifi button off/on. Not sure what is wrong.
Model: R7900P|Nighthawk X6S AC3000 Tri Band WiFi Router
Message 1 of 7
Guru
Re: WIFI not showing
The wifi on/off button needs to be pushed for 2 seconds. Did you hold it that long?
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 7
McSkrillz
Yes, I held it down until the light went off, then i held it again until the light came back on.
Message 3 of 7
Guru
Is it broadcasting? And you just not able to connect?
Are you able to connect but get "connected, no internet available"
or is it not broadcasting at all?
Firmware on it?
Message 4 of 7
McSkrillz
It's not broadcasting.  When I pull up my wifi options on my phone, or any other device, it doesn't show any of my wifi as options.  On the netgear genie app it shows that the wifi is working, but it doesn't show as an option to connect on any device i bring next to it.
Message 5 of 7
DarrenM
Sr. NETGEAR Moderator
Have you tried to change the SSID On the router?
DarrenM
Message 6 of 7
Guru
If you log into the device, is "enable ssid broadcast" checked?
Also, whatt firmware is on it?
Have you tried a simple factory reset and manual re-install?
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 323 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
