Reply
Highlighted
Follower
X Box Issues
I have my X Box set to highest and the X Box IP address in the DMZ but I still get a moderate NAT setting instead of open. Any ideas?:eek:
Message 1 of 2
Highlighted
Luminary
Re: X Box Issues
No need to DMZ your XBOX1, setup port forwarding rules if you have ONLY 1 Xbox.
1) Check UpnP
2) Turnoff upstream & Downstream QoS
3) Port Forwarding Rules, BELOW
Xbox Live requires the following ports to be open:
Port 88 (UDP)
Port 3074 (UDP and TCP)
Port 53 (UDP and TCP)
Port 80 (TCP)
Here are the 3 additional ports that are needed for the X1
Port 500 (UDP)
Port 3544 (UDP)
Port 4500 (UDP)
Let us know how the XBOX1 works after settings are changedSmiley Very Happy
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3036 views
  • 0 kudos
  • 2 in conversation
Announcements
