× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
is the NIGHTHAWK® AX5200 AX6 DMZ capable
gdahl7
Follower
Hello,
I would like the option for a DMZ. Will the NIGHTHAWK® AX5200 AX6 do this?
Thanks,
Gary
Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
Message 1 of 3
Re: is the NIGHTHAWK® AX5200 AX6 DMZ capable
Visit the support pages:
Support | NETGEAR
and feed in your model number and check the documentation for your hardware.
You may have done this already, but I can't tell from your message.
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
Is the Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0 listed in your footer involved in this in anyway? Or did you just click the first thing that popped up when you wrote your message?
Message 2 of 3
microchip8
Master
Most NETGEAR routers support DMZ
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 608 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
