Discussion stats
  • 1 reply
  • 2420 views
  • 0 kudos
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
Follower
nighthawk r7900 after power outage are having problem connect iPhone and iPad to network
I am conneting fine with my Imac to the router, can see my netgear device on iPhone but it will not connect.  Any suggestions
Model: R7900|Nighthawk X6 AC3000 Tri-Band WiFi Router
Message 1 of 2
Highlighted
Guru
Re: nighthawk r7900 after power outage are having problem connect iPhone and iPad to network
Are all radios configured ot the same SSID and password (network key) for simplicity? Easy to overlook ie. the seoncd 5 GHz interface in the UI for example - unless Smart Connect is enabled, which does force both 5 GHz radios to the same config.
Message 2 of 2
