Reply
no internet connection after trying to connect wifi extender
hankdogvi
Tutor
I tried to connect a TP Link wifi extender to my Nighthawk. I was unable to connect and now the router has stopped providing internet access. I talked with the service provider and confirmed that I was getting signal from the modem to the router, but the wifi connection on both bands shows "Connected, no internet." I have reset the router to factory settings, and still only get "Connected, no internet.
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 5
Guru
Re: no internet connection after trying to connect wifi extender
What modem is it?
What tp-link adapter?
What firmware is on the R6700?
did you reboot devices in this order:
1. Shut off modem and router and disconnect everything from both.
2. hook up coax to modem, power it on. give it a few minutes to fully boot.
3. connect ethernet from modem to R6700.
4. boot up r6700. give it a few minutes to fully boot.
5. Try to setup the r6700.
in terms of setting up the extender, try the setup not using wps. use tp-link's installation wizard and not wps .Maybe something isn't correct between their wps coding.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 5
hankdogvi
Tutor
Modem is a Technicolor model DPC3216
Extender is TP Link AC 75
Not sure of the firmware on the router, but model shows R6700v3
I tried to connec with WPS and I suspect that is part of the problem.
I have rebooted several times, but only waited around 15 seconds each time. I'm giving it a longer rest now.
If I can get back on, I will try to connect the extender with the TP Link app.
Message 3 of 5
hankdogvi
Tutor
I gave both the router and the modem a longer rest, still "connected, no internet."
The link lights on the modem and router are flashing in synch, so I believe the internet signal is getting to the router.
Message 4 of 5
Guru
Couple things to try.
1. replace the cable between the modem-router
2. factory reset the R6700 and try to install that route.
3. maybe something was corrupted within the R6700. try re-installing the current firmware, resetting, re-installing. a factory reset only removes, settings, it doesn't overwrite the firmware
4. downgrade the firmware a version.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 341 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
