aisorn
Dec 16, 2018Aspirant
red right only
What should i do , It only red light power on only
You will need to contact support as there could be a hardware issue with the unit.
https://www.netgear.com/support/contact.aspx
DarrenM
- aisornAspirant
no , sometime white light
schumaku wrote:
What should I do if the Power LED on my Nighthawk router stays amber and does not light white?
Greetings aisorn,
Did you perform the reset procedure in the link schumaku provided?
Wat were the results?
3 possibe causes fo this behavior:
-Corrupt or incomplete FW
-Defective hardware
-Weak or defective power supply
If a reset doesn't work via the reset button, attempt to manually reflash the FW from a machine connected via ethernet. TFTP is built into windows 7/8/10. Please post your progress.
