Reply
slowing down my internet speed
Rudy479
I have a netgear N600 router hook up from the wall and Nighthawk router R7000 for wireless. When i hook up my computer to the N600 i get download speed of 110 mbps & upload 12 mbps. when hook up to R7000 i get speed download & upload of 12 mbps.Now that i switched the router to AP mode iiam getting download 110 mbps & upload of 12. Is that good or should i try something else?
Rudy Enriquez
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 5
Re: slowing down my internet speed
@Rudy479 wrote:
I have a netgear N600 router hook up from the wall ...
Which router. N600 is a (slow) wifi speed designation, not a model number.
Which router have you switched to AP mode? If it is the R7000, then I am surprised that it worked at all in router mode. Two routers on the same network is a recipe for trouble.
But not knowing you network layout that is just a guess on my part.
I do hope the other router is not so old that it has LAN ports that run at 100 Mbps. Connecting anything to that will slow things down. It is slower than your Internet link. Then again, you haven't said what that is either.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 5
Rudy479
When i hook up my pc to WNDR3700 i get speed of 110 which is good i guess. But for some reason my nighthawk R7000 slows down my speed 12mbps. It help alot when i switch to AP Mode. I just did a test speed and i got 101. So is that a good speed?
Rudy Enriquez
Message 3 of 5
Rudy479
Sorry Michael,
It's not a n600 it's a C3700.
Rudy Enriquez
Message 4 of 5
OK, so, as I understand it, the modem is the C3700. It is really a Cable Modem Router.
If you use the WNDR3700 you get 110 Mbps. (Is that wifi?)
If you use the R7000 in router mode you get 12 Mbps.
If you use the R7000 in access point mode you get 110 Mbps.
If this is wifi, 110 Mbps. maybe the best you will get. That depends on the wifi clients.
If you are using the C3700 as a modem/router, then you could also consider putting it in modem only mode.
There is a manual for the C3700 somewhere at the end of this link:
>>>> C3700 | Product | Support | NETGEAR <<<<
See page 11.
Just another user.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1935 views
  • 0 kudos
  • 2 in conversation
Announcements
