Reply
wifi speeds great on my imac terible on anything else
chriscollins30
Follower
Recently just installed the r7000 to fix the terrible wifi speed that i have been getting. Currently i have my 2013 27in Imac running on wifi and i am getting the full speed of my internet (25meg) but every other device that is connected will only sporadically pull 25meg. they typically pull 1.5 to 4 meg. that is even sitting less than 2 feet from the router. The signal strength is fine, but the speed is horrible. Anybody have any suggestions?
Message 1 of 3
techfreak8
Re: wifi speeds great on my imac terible on anything else
Maybe you need to power cycle all your devices, and make sure your router is in a good position. Make sure your router has no interference or less as possible choose best channel 1,6,11. If nothing works then your router has a firmware issue what's your firmware version?
Message 2 of 3
Retired_Member
Not applicable
If you are using the same SSID on this router as you were on your old one, you may need to delete the wireless profile or (forget the network on an IOS or Android device) and reconnect again.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1802 views
  • 0 kudos
  • 3 in conversation
Announcements
