ZI_95
Dec 26, 2019Aspirant
Access Controls Changes not Working
I recently purchased a Nighthawk AX4: RAX35, not RAX40 (it seems that my model is not even available in the model recommeded section) router this past black friday. I enabled Access Controls in an attempt to block/limit internent access for certain devices. The problem I am having is that none of my changes are sticking. I will go and block a device, then 5 seconds later it gets unblock. I try to change a device name and once again it resets. Whats interesting is that I was able to enable it but now when I even tried disabling access control, but it will not disable. Whenever I make my changes I make sure to hit apply, but to no avail. My firmware is also up to date Firmware Version V1.0.3.62_1.0.1.
- Christian_RNETGEAR Employee Retired
Hello ZI_95,
Thanks for reporting the issue you're experiencing. I have sent you a message requesting for more info. Please respond at your earliest convenience.
Thanks,Christian
- IGKTutor
RAX35. Netgear support. I was on hold for more than 1.5 hours. Case number 42166452. Please call me ASAP before I return the product.
- IGKTutor
I wonder why I didn't get a response.
For - Nighthawk AX4: RAX35
Having same issue.
When trying to change Access Control (Security > Access Control) radio button to "Block all new devices from connecting" and attempting to click the "Apply" button to enable this change it will not save which basically makes the function unavailable.
I can see that "Allow all new devices to connect" is the recommended default but I've always been able to use this option on prior models.
Was hoping this would be resolved by now. I have also had my router since around the middle of December 2019.
Please advise.
Hello anetworkinguser,
Welcome to the community! Have you gotten a chance to contact our Support Team about this?
https://www.netgear.com/support/default.aspx
Christian
- IGKTutor
I'm having the same issue. Did they tell you how to fix it?
- ZI_95Aspirant
So sorry, but I returned it before they could get back to me.
- hyndsyteAspirant
Same issue RAX35. Access control not working or blocking anything at all. I reformatted the router it it worked for awile. I have the latest firmware V1.0.3.62_1.0.1, updated through the router itself. Access Control is the most imortant part of the router for me. The problem has been an issue with every firmware since purchase. It doesn't act up at first. Given time it stops working.
- hyndsyteAspirant
With the fact that you can't find this router online. The RAX40 always comes up. Unless you registered the RAX35 with Netgear. You can't even find it listed on the netgear site. It seems this was a "BLACK FRIDAY" special. Meaning that we will likely never get a fix for this, as Netgear doesn't seem to support this model anymore. It's a shame I spent money on faulty product. I'll just have to save up for the RAX40 I guess. Even if I'm hesitant to give more money to them. This IS the first issue I've had with a Netgear product. Technically the router works, just doesn't restrict anything with Access Control. Even saying it blocks by default. A new devices wasn't denied access.
