× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Ax5400/Rax50 Smb Version Supported
anicaretta3
Does anyone know which Smb versions are supported by the RAX50/AX5400? Tech support was unable to provide an answer and I don’t want to end up in the same situation that I currently have with my WNR4500/N9000 where it only supports Smb 1.0. Thanks in advance!
Message 1 of 4
Guru
Re: Ax5400/Rax50 Smb Version Supported
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wif...
Thank you.
Message 2 of 4
Guru
You might as a forum moderator and see if they can tell you.
Though from this users post, his RAX80 series seems to be working with Windows 11 and USB storage so this would kind of inidicate SMB version being used would be something other than v1.
Message 3 of 4
anicaretta3
That makes sense, hopefully that is the case. I'll post over there and take a look at the other posts, thanks!
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1233 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
