- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
C7000v2 upgrade to....rax80??
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: C7000v2 upgrade to....rax80??
If you're needing extenders, you'd probably be better off to go with a mesh system.
reason why is the upgrade to AX didn't add a whole lot of extra range. What it added that's big was concurrent broadcast (communication with more than 1 device at a time)
the move the mesh would add seamless roaming, better coverage, and more stability. But I'd recommend the triband mesh systems and not the dual band.
In terms of modems on xfinity capable of gig speeds:
CM1000
CM1100
CM1200 (wouldn't recommend on xfinity)
CM2000
All are docsis 3.1 and so compatible with gig speeds.
- Mark as New
- Bookmark
- Subscribe
- Permalink
And if not, what mesh systems do you recommend? The wifi5 or wifi6 orbi?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Kttiekat wrote:
What if we replaced our current extenders with the eax80? Keeping the c7000 modem/router?----Extenders rely on the router, so even though the extender is AX its running off an AC system so won't perform better than the AC devices.
And if not, what mesh systems do you recommend? The wifi5 or wifi6 orbi?---Depends on performance needs and budget. I have a lot going on at my place and an AC system it fine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for your feedback, I really appreciate it. I have a six week old and my brain is fried!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've used the orbi RBK53 and RBK43 system and both have worked great for me. I haven't used the AX series so far. Maybe in the future but I can't justify the cost right now. Plus I can hit 200mbps+ over wireless and hit gig speeds wired so it covers all my needs.
If you don't pay for gigabit speeds, the c7000 can be switched over to modem only mode. Then you can hook a mesh system to it without problems.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did read we could use the c7000 as a modem, but didn’t know if that is going to just cause us the same issues. Hope I’m making sense. I would just go to Best Buy and pick their brains but getting out of the house is about impossible these days and really just not comfortable with a newborn. ☠️
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The cbr40 won't hit gigabit speeds for most providers beause its not docsis 3.1. The C7000 and the CBR40 have the same internal modem. You use your C7000 as a modem and just go with the RBR40 version/kit. If you got the kit, it either comes with 1 or 2 satellites depending on the kit you get.
Plus that way if you ever did want to go to gigabit, you could get a gigabit capable modem (see the ones outlined above) and run the rbr40 off it.
