× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
CAX80 Support for Static LAG
dusteraz
Will support be added to the Nighthawk CAX80? In the user manual on page 60 it mentions the options of LACP and Static but I only have the options for Enable (LACP-IEEE 802.3ad) or Disable, there is no Static option.
I'm trying to set this up with the Nighthawk S8000 switch which doesn't support LACP.
Message 1 of 2
nEo717
Guide
Re: CAX80 Support for Static LAG
I have and use CAX80 -- It has Mult-Gig port which if have 10G (or mult-gig switch) elimates the need for LAG -- It has area in Advanced Setup for Ethernet Port Aggregation, LACP-IEEE 802.3ad (which is Dynamic link aggregation standard). Another method is since the port is mult-gig on CAX80, it will connect to full duplex gigabit switch then passing on speeds beyond 940Mb/s (I get 1,208 Mb/s normally).
Message 2 of 2
Discussion stats
  • 1 reply
  • 663 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
