MarkMag's avatar
MarkMag
Follower
Jul 12, 2022
Can I Bridge my RAX70 to my RAXE300?
I can't find any options in setup for my RAX70 to put it into Bridge Mode.
I bought the RAX70 while I waited for my backordered RAXE300 to come in and it did a fantastic job as a wireless router, however the signal is weak on the far side of my house, I though it would be great now that I have two units to place them on opposite ends of the house, using the RAXE300 as my primary and the RAX70 as wireless bridge. But I just can't figure out how to make this work. Is this possible? If so, what do I need to do?
Thank you.
1 Reply
  • FURRYe38's avatar
    If you see Bridge mode under Advanced tab/Advanced Settings/Router mode, then yes. If it's not there, then the RAX70 doesn't support wireless bridge mode.
