× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Does anyone know if the fan is a push or pull?
mynameisjon
Follower
Does anyone know if the fan mounted at the top is a push or pull type fan?
The airflow is really low so it makes it hard to tell from feel.
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 2
Newfiedrool
Virtuoso
Re: Does anyone know if the fan is a push or pull?
I believe it extracts the air out of the top vent.
Message 2 of 2
Discussion stats
  • 1 reply
  • 481 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
