× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Ethernet Ports on RAX50 (AX5400)
pmokover
Tutor
Do the four Ethernet ports on the RAX50 (AX5400) router support PoE or PoE+?  According to the specs on the Netgear website they do.  That would be great if true but I'm guessing it's just a typo.  See attached photo.
(Note: I am asking about PoE (Power over Ethernet), not PPPoE which is a different thing.)
Thanks!
Message 1 of 3
antinode
Guru
Re: Ethernet Ports on RAX50 (AX5400)
> [...] See attached photo.
   Which you found where, exactly?  (Thanks for the helpful link.)
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get some.  Read.  Look for "PoE".  (Prepare for
disappointment.)
Message 2 of 3
Razor512
Prodigy
The RAX50 does not have any POE ports, basically is is a single gigabit WAn port, and 4 LAN ports each at 1GbE.
If you need POE, then you will be stick with either getting PoE injectors or buying a basic POE switch.
If you end up going the PoE switch route consider getting something slightly higher end so that you have more room to grow.
Message 3 of 3
Discussion stats
  • 2 replies
  • 1178 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
