× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
How many RAX10-100NAS can be managed from a single web interface?
Omar-
We need to buy several AX1800 (RX10) Wi-Fi routers and put one in each site. can someone tell what is tha max number of this router can be managed from a single web interface? for example : we would like to see all of them and if one goes offline in a single web interface
Thanks
Message 1 of 4
Guru
Re: How many RAX10-100NAS can be managed from a single web interface?
Remote management using routers web page is no longer supported. Only remote management is used thru the Nighthawk app.
When older routers supported remote web page management, only could access a signal router per site at a time.
Message 2 of 4
Omar-
Thanks! do you know the max number of routers I can link to nighthawk?
also is there any current netgear router that supports both web interface and app management?
Message 3 of 4
Guru
All NG routers have a web UI management page. Just have to be locally connected.
I believe you can have many routers connected to the NH app. Not sure how the app handles same model router though. I presume it will separate them due to the serial number being different.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 365 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
