×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
I bought a Netgear Access Point (WiFi 6 AX1800 POe) AND NEED TO SET IT UP BUT THE INSTRUCTIONS ARE T
daroldog
Follower
Message 1 of 2
Guru
Re: I bought a Netgear Access Point (WiFi 6 AX1800 POe) AND NEED TO SET IT UP BUT THE INSTRUCTIONS A
You gave us nothing to go off.
AX1800 is not a model #...
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router RBK963 and RBK853 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 2
Discussion stats
  • 1 reply
  • 294 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
