Orbi WiFi 7 RBE973
Reply
IPV6 pin hole capability?
Animetoys
So first time poster (mercy please) here, as my ole Verizon FIOS router died. I purchased and setup a Netgear NightHawk AX3000 4-Stream WiFi6 Router RAX36S (with a firmware version of V1.0.4.46).
So the question, on the Verizon FIOS router it had an option called IPV6 pin hole, where I could allow any IPV6 address access to a system (a raspberry pi) on my private network over TCP port 9001 in this case.
Within the AX3000 RAX36S router's Advanced Setup drop down under Port Forwarding I was able to allow any IPV4 address access to this system (which has both an IPV4 and IPV6 address) over the port mentioned above. But I don't see an option to do this for IPV6 addresses?
While still under the router's Advanced Setup going to the drop down under IPV6 my internet connection type is "auto detect" which returned the connection type of 6to4 Tunnel. I noticed under both the WAN  and IPV6 setting sections there is a filtering option with the choices of Open or Secure, changing one or the other or both doesn't seem to let me do the IPV6 pin holing I am trying to accomplish.
Am I missing something or is there currently no way with this router to allow the forwarding of a single port if the IP used is IPv6?
Thank you.
Message 1 of 6
Accepted Solutions
Guru
Re: IPV6 pin hole capability?
I've never seen any pin holing (yes I did go down a rabbit hole after your message) on any of the consumer netgear equipment. I've not been on the business side of things so I can't attest to those. Most users just use the port forwarding option that you've had to be currently using.
And with pin holing tending to be an enterprise feature, you might look towards more business class equipment if that's a feature you're wanting/needing.
Message 5 of 6
All Replies
Guru
Not sure exactly what the "pin hole" feature you're referring to but I use a pihole on my network. works well.
What are you wanting to achieve with this pin hole using your pihole?
Message 2 of 6
Animetoys
Thank you for the response. I use numerous raspberry pi devices on my internal network. While I do use one of them as a pi-hole, the need for the IPV6 pin holing aka: in computer networking, a firewall pinhole is a port that is not protected by a firewall to allow a particular application to gain access to a service on a host in the network protected by the firewall (or router), for my TOR relay that I have hosted for years. The TOR relay (running on one of my other raspberry pi devices) is currently accepting inbound traffic over the TCP port for IPV4 traffic due to the port forwarding rule I put into place on the router. However, I don't see anywhere I can put add a pinhole for IPV6 traffic.
I also host a transmission server (on another raspberry pi device) which I was able to again do IPV4 port forwarding on via the router. The ISC DShield honeypot I run on another raspberry pi device didn't need port forwarding as I put the system in as my DMZ host.
Anyways, BLUF I have a TOR relay running on a raspberry pi that I would like to have IPV6 traffic from the internet forwarded to the device over a single port, but I can't see to find the IVP6 option, which was available on my old Verizon router. I found the option to allow this traffic to this device for IPV4.
Any follow up input from you or others in this forum is appreiated.
Again thank you for responding to my RFI.
Message 3 of 6
Animetoys
Have you or anyone else had a chance to look into why IPV6 pin holing on my nighthawk rotuer is not a thing? I'm glad I was able to explain what other capabilities raspberry pi microcomputers have to you, but I was hoping you had a suggestion on an option I was missing?
I guess I could always just buy another Verizon FIOS router as I know it had the capability.
Message 4 of 6
Guru
Message 5 of 6
Animetoys
Thank you for the support, your time and verification of features and functions available to me using my new Netgear router. While I would like the IPV6 port forwarding/pin-holing functionality, I can do without it as the only thing I was using it for before was to allow people to connect to my raspberry pi hosting the TOR relay via IPV6.
I do like having much more control over my router then what I had with the Verizon one.
Thank you again!
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1106 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
