× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
Internet For Entire Home Goes Out When I Plug Ethernet In
Inglorious
Nighthawk AX4500.
Topic, when I plug the Ethernet cable into the router for my PC, my entire internet including wifi goes out. Internet went out at 3 PM yesterday, it is 5:43 PM and I have had wifi for an hour uninterrupted without Ethernet plugged in. Friend who was a ISP service tech helped me get it to this point but we have no idea why the Ethernet cable makes it all go out.
Message 1 of 9
CrimpOn
Guru
Re: Internet For Entire Home Goes Out When I Plug Ethernet In
First step is to try a different Ethernet cable.
Is the PC connected only to the router with a cable? (no simultaneous connection to anything else, even over WiFi?)
Are there any Ethernet switches involved?
Message 2 of 9
Inglorious
No switches involved, I do use two cables and a splitter. Will try using different cables as my next step if it doesn't work tonight when I plug in again. That didn't come to the top of my mind just because if it's causing the entire internet including wifi to go out I thought it IP or router itself related.
Message 3 of 9
CrimpOn
Guru
Please explain this in more detail.
In the days before gigabit Ethernet, it was common to use two pairs of a cable for one Ethernet connection and the other two pairs for a separate Ethernet connection.  Gigabit Ethernet requires all four pairs, so this technique no longer works.
Message 4 of 9
Inglorious
Sure -- the router has to be in a different room so my PC is connected with two cables via a splitter to reach.
Message 5 of 9
CrimpOn
Guru
Splitter is a very specific term.  They are normally deployed in pairs
Can you attach a picture?
Message 6 of 9
Inglorious
PXL_20231008_025841824~2.jpgthis is what I mean. I had my Ethernet cable unplugged for 4 hours with 0 issues. Within a minute of plugging my desktop back in my entire network went down again.
Message 7 of 9
CrimpOn
Guru
Thank you for the picture.  That is what is usually called an "RJ45 Coupler" (not a "Splitter").This is a most unusual situation.  With the problem happening when the desktop computer is connected to the router, the obvious areas of concern are:
  • The computer, or
  • The cable.
What I (personally) would do is purchase a 100ft Ethernet cable from Amazon (under $20US) and connect the computer directly to the router using this cable.  (The family will shriek, "what are you DOING???" and you will reply, "It's just for a few minutes. Please don;t trip on it.")
I would also look very closely at those tiny gold wires in the RJ45 jacks (router and computer).  Maybe one of the wires is bent.
Message 8 of 9
Inglorious
I'm going to get a cable and a USB to RJ45 adapter for the PC. I tried all four ports on the router and the issue persisted when it plugged in, so if the router isn't the problem I'm confident I narrowed it down to cable and PC with your help. Will report later!
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1515 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
